hi guys,
i am looking for a real specific solution.
My prob is that my Router(https://www.amazon.de/Telekom-40275352-Speedport-Hybrid-Router-Weiß/dp/B00U0EIQ2K) is so much crap. I would like an enterprise solution like a device from cisco, juniper, hp and other big playerz but they dont offer such a device. So a custom router is the solution. I prefer a firewall router system like pfsense or ipfire. Now which hardware is the right one and what LTE equipment (SIM Card Slot/ Antenna/ Modem(mybe pcie)) do I need for an enterprise solution?
Because its both LTE and DSL.
ty BLVCKRIPPER
PCMASTERRACE:
Intel Core i7 4790K @4,8GHZ | ASUS GTX 1080TI 11GB StriX OC @2 ghz | MSI Z97 Gaming 7 | G Skill Sniper 1866mhz 16gb | 750 Watt Corsair Power Supply
Zalmann Z11 + | BeQuiet Dark Rock Pro 3 | 6TB + 500 GB HDD | 250GB SSD | 500GB SSD
Samsung SyncMaster S22B300B | Benq RL2455HM | Acer XF270HUAbmiidprzx
Zowie FK2 |Corsair K70 LUX MX RED | Razer Megalodon 7.1 Headset | Auna Mic 900B | XXL Mousepad from TrilluXe
SV:
AMD FX 4100 | MSI 760GMA-P34 | 1TB HDD | Intel PRO 1000 PT | 8GB DDR3 non ECC | 500 watt gold PSU | Xilence AMD 3+ cooler
https://linustechtips.com/topic/917426-diy-lte-routermodem/
You need a modem for these services. Pfsense only does the router part. Your not going to find a modem that can do dsl and lte. Even finding a router with lte support is hard. Any way you look at it you need to find modems to get service.
I would like to mention that Synology has a few routers that you can connect an 4G USB modem to. Any router should work with dsl and cable internet.
https://linustechtips.com/topic/917426-diy-lte-routermodem/#findComment-11250594
I’m not aware of any enterprise or prosumer grade equipment that has both DSL and LTE. What I would do is get a DSL modem, a Mikrotik router, and a USB LTE adaptor. Or if you really want something that at least has the LTE built in, Mikrotik makes the “wAP LTE” which is has 2.4GHz wifi and an LTE modem.
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
https://linustechtips.com/topic/917426-diy-lte-routermodem/#findComment-11252432
