Helping a friend with a parts list. Going to help him build his first pc.
https://pcpartpicker.com/list/fKjK4q
  • Budget $900-$1000.
  • Games like Battlefront 2, and pubg, and csgo are going to be played on the pc.
  • Black and Red Theme if possible
  • $USD
  • Budget around $250 for monitor and keyboard. (already has steel series mouse)
Any suggestions or changes?
https://linustechtips.com/topic/917308-pc-build-review/
I say everything is just fine but the RAM. Try to just squeeze ever so faster RAM in the build since Ryzen loves its RAM speed. Other than that it should be respectable xD
Primary Laptop (Gearsy MK4): Ryzen 9 5900HX, Radeon RX 6800M, Radeon Vega 8 Mobile, 24 GB DDR4 2400 Mhz, 512 GB SSD+1TB SSD, 15.6 in 300 Hz IPS display
2021 Asus ROG Strix G15 Advantage Edition
Secondary Laptop (Uni MK2): Ryzen 7 5800HS, Nvidia GTX 1650, Radeon Vega 8 Mobile, 16 GB DDR4 3200 Mhz, 512 GB SSD
2021 Asus ROG Zephyrus G14
Meme Machine (Uni MK1): Shintel Core i5 7200U, Nvidia GT 940MX, 24 GB DDR4 2133 Mhz, 256 GB SSD+500GB HDD, 15.6 in TN Display
2016 Acer Aspire E5 575
Retired Laptop (Gearsy MK2): Ryzen 5 2500U, Radeon Vega 8 Mobile, 12 GB 2400 Mhz DDR4, 256 GB NVME SSD, 15.6" 1080p IPS Touchscreen
2017 HP Envy X360 15z (Ryzen)
PC (Gearsy): A6 3650, HD 6530D , 8 GB 1600 Mhz Kingston DDR3, Some Random Mobo Lol, EVGA 450W BT PSU, Stock Cooler, 128 GB Kingston SSD, 1 TB WD Blue 7200 RPM
HP P7 1234 (Yes It's Actually Called That)  RIP
Also im happy to answer any Ryzen Mobile questions if anyone is interested!
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248466
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($170.89 @ OutletPC)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($74.89 @ OutletPC)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card  ($314.98 @ Newegg Business)
Case: NZXT - S340 (Black/Red) ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($53.88 @ OutletPC)
Monitor: AOC - G2460PF 24.0" 1920x1080 144Hz Monitor  ($183.97 @ Amazon)
Keyboard: Corsair - K65 RGB Wired Gaming Keyboard  ($78.99 @ Amazon)
Other: ryzen 2600 ($200.00)
Other: some b450 motherboard ($100.00)
Total: $1237.59
Generated by PCPartPicker 2018-04-16 20:00 EDT-0400
Ryzen 2xxx series comes out in a week, as will 400 series motherboards.  Spend $100 more and get a 2600, a motherboard will most likely be around $80-$100, but I added more, faster ram, a better psu and a better ssd. EDIT: also the cooler you added is pretty bad, the stock ryzen cooler it pretty good, so I'd keep it.
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248473
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($174.98 @ Amazon) wait for the ryzen 2600.
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard  ($70.00 @ Newegg)
Memory: Patriot - Viper 4 16GB (2 x 8GB) DDR4-3000 Memory  ($164.99 @ Amazon)
Video Card: Gigabyte - Radeon RX 580 8GB AORUS 8G Video Card  ($359.99 @ Amazon)
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($34.33 @ Newegg)
Keyboard: Corsair - K63 Wired Gaming Keyboard  ($59.99 @ Amazon)
Total: $1173.13
Generated by PCPartPicker 2018-04-16 20:32 EDT-0400
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248564
  • $USD
Looks fine, dont get the CPU cooler the stock Ryzen one is just fine, i would say get higher speed ram something like FlareX, The SSD you picked is one of the best on the market (not size wise). Also you could always go with a Ryzen 5 APU. This is Build #1 https://pcpartpicker.com/list/QkGDxG
APU Build: https://pcpartpicker.com/list/tMfjpG along with some benchmarks to show you that you will get the same/slightly lower frames https://videocardz.com/74961/amd-ryzen-5-2400g-synthetic-and-gaming-benchmarks-emerge
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248585
4 minutes ago, TSL said:
Consider waiting another 3 days for next-gen Ryzen CPU's? Also perhaps you would consider a switch to an Intel based system as both PUBG and CSGO prefer these CPU's for their higher clock speeds.
Saying that they "Prefer" a cpu over another is false, if that was the case people would chose the meh intel CPU over a high end AMD or mid tier AMD CPU, also benchmarks prove otherwise
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248591
Total: $1237.59
 Why would he get that memory for 4$ more he can get 3200 Ripjaws 16gb? Also that SSD isnt inherently better the real "better" thing about it is its price
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248600
I just didn't see that memory I accidentally bumped it out in the price slider my bad, but the ssd is decent quality and saves about $30.  The evo is definitely better, but has become overpriced.
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248623
True but Newegg has it off for 30$ due to a sale i believe
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248629
https://imgur.com/gallery/ESjL0
https://www.youtube.com/watch?v=4YsronujQB4
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248631
Friends not going to play pubg that much. Mainly csgo and fortnite. Is their a big difference in performance in csgo with intel cpu compared to amd?
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248634
Just now, TSL said:
Both of those tests are "old" objectively there is such of a thing called optimization. Also why spend more for a intel CPU that COULD give him more frames but it doesnt matter because he is only on 144hz not 240hz
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248640
Intel will perform significantly better in CSGO to the point that I would consider the platform change. I cannot speak for Fortnite as I haven't seen benchamarks, but given it isn't a greatly GPU bound game, it is likely that it would follow the same trend as CSGO
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248642
skip to 4:30 for recent benchmarks for PUBG.
An extra 25FPS on top when comparing the 8400 to Ryzen 1600 plus much better 1%lows. This gap will also increase as you lower the detail settings to become less GPU bound.
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248653
Still months ago again not updated.  Also for Ryzen to be fully taken advantaged of you need the correct ram, he doesnt say what ram it is at the given time. Just take a look at Pauls Hardware, Bitwit, Gamers Nexus, etc.
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248674
the evo isn't any better in performance, it's about the same as the MX500 but the MX500 has a higher endurance rating and much cheaper.
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248696
PUBG hasn't had major optimisation changes like the 1.0 update. This is relevant, please stop banging on that Ryzen is better in this case when it's not. The chip was oc'ed and running 3200Mhz. it was given the best possible chance, it just wasn't as good. Because pubg wants clockspeed as does CSGO. Don't get me wrong, Ryzen is still capable but intel is just a bit better in these circumstances. And with the budget motherboards been release for intel, their price to performance is near equal
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248700
When did i ever say Ryzen was better? also saying that the bang for buck is equal is absurd. And riddle me this why spend more money to get more frames when you cant take advantage of them and in fact it could lead to more issues
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248709
You alluded to it. Yes the bang for buck is nearly equal. What do you mean can't take advantage of more frames? In what way?
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248719
higher frame rate over what your monitor can handle can cause screen tearing, V-Sync can prevent this, while G Sync prevents screen tearing for lower then your refresh rate (dont quote me on this, this is how i was explained it). So more frames can do more harm then good in a lot of use cases.
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248726
1 minute ago, Dreaper said:
higher frame rate over what your monitor can handle causes screen tearing, V-Sync can prevent this, while G Sync prevents screen tearing for lower then your refresh rate (dont quote me on this, this is how i was explained it). So more frames can do more harm then good in a lot of use cases.
As a user of a 6700K OC'ed to 4.8GHz, and I have about 1800Hrs in CS, whilst running a 144Hz monitor, I can assure you, there is no screen tearing
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248730
1. Do you know what screen tearing looks like? 2. Is V sync/Gsync on? 3. I said can cause its different for everyone, i dont know about you but i would rather be safe
https://linustechtips.com/topic/917308-pc-build-review/#findComment-11248739
