In this video benching X299
The result for CS:GO at 4k at very high settings is 291 FPS. I was wondering if anyone knew how Linus gets his average fps. In an actually game that seems really high to me. I was also wondering if anyone had tested a system with a 1080ti and a 7700K running at 1440x1080 4:3 at medium to low settings. For non csgo players asking wtf why such low everything on such a beast setup, FPS is everthing to the most competitive csgo players.
https://linustechtips.com/topic/917010-how-does-ltt-bench-cs/
3 minutes ago, Droidbot said:
He tests it using uLLeLetical's FPS benchmark, I think?
https://steamcommunity.com/sharedfiles/filedetails/?id=500334237
Highest settings running that bench I believe.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/917010-how-does-ltt-bench-cs/#findComment-11245781
Just now, thecooleo said:
Thank you droid so by far the best thing i can do is upgrade to an unlocked CPU and overclock it if I understand this correct
If you have a Z series board, yeah. CSGO really doesn't exercise the GPU hard, so get a better CPU for now (quad core is fine, CSGO doesn't use HT or more than 4 cores super effectively, but they might count for background tasks more) or just wait for Source2 to actually see better performance.
idk
https://linustechtips.com/topic/917010-how-does-ltt-bench-cs/#findComment-11245788
I mean you could upgrade to a 7700K, but it's not going to make too big of a difference really.
https://linustechtips.com/topic/917010-how-does-ltt-bench-cs/#findComment-11245805
