Hello everyone and anyone!
I’ve been a long time desktop user and haven’t really worried about getting a decent laptop till now. I’ve gotten a new job and will be moving to a home with less space, unfortunately not enough space for my computer. So my GF will be taking care of my PC till she can eventually join me later in the year.
Anyway, point is, I am in the market for a new gaming laptop and while I have been looking around a little, I have not decided yet and would like some ideas from you. 9_9 Before I list some preferences it’s worth saying that the place I’ll be going to provide a discount on Dell hardware, but I’m not overly struck on the big clunky aesthetics.
I am looking to spend around £1800 GBP for ideally a gaming laptop with portability in mind. This has made me think of the Razer blades but I’m not 100% sold on them and want to know my options first. I’m not overly fussed on the specs but I like to futureproof a little, (which is difficult with no upgradability normally) and for the money and gaming it should have in the region of:
  • Atleast i5 but really should be an i7 for the money
  • atleast 16GB of RAM
  • GTX 1060 minimum
  • 500GB storage minimum (PCIE minimum but M.2 probably ideal), ideally 1TB.
Also to consider:
  • Touchscreen, 2 in 1 functionality and decent webcam are all pluses.
  • Portability, I don’t want a laptop with bigger radiators than my car.
So what would you recommend? Thanks in advance!
Rob
https://linustechtips.com/topic/916284-help-deciding/
Wait for more CFL-H laptops like Clevo P950EP6/P950ER and MSI new GS/GE Raider. If you can find a Zephyrus M (not to be confused with the old Zephyrus) within your budget then it can be a good buy too, just be aware of the poor battery life. RAM and storage can be added after purchase if the warranty allows.
You won't find a 2 in 1 with touchscreen and GTX 1060 unless someone makes a new model.
Avoid Razer laptops, terrible quality, terrible QC and customer support.
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/916284-help-deciding/#findComment-11239893
2 hours ago, rob3342421 said:
How long till they’re available? And could you send me a link to some examples?
1-2 weeks for selected models. Other models need to wait a few months. Examples are the ones I listed above.
Desktop specs:
https://linustechtips.com/topic/916284-help-deciding/#findComment-11246099
5 minutes ago, rob3342421 said:
MSI GS65
No proper reviews yet. From early verdicts: chassis has too much flex, cooling is questionable.
Desktop specs:
https://linustechtips.com/topic/916284-help-deciding/#findComment-11268678
13 minutes ago, rob3342421 said:
http://laptopmedia.com/laptop-specs/msi-gs63-stealth-8re/
whats your opinion? This seems like a good value option to me but what do you think?
I mentioned it before:
Look for Notebookcheck and Ultrabookreview on GS63VR. However I strongly suggest Clevo P950EP6/P950ER over this.
Desktop specs:
https://linustechtips.com/topic/916284-help-deciding/#findComment-11291781
10 minutes ago, rob3342421 said:
Clever aren’t available in uk and from what I can tell the vr isn’t available in uk too annoyingly
It's available, but not in stock:
https://www.pcspecialist.co.uk/notebooks/defianceXS-II-15/
Also consider Mechrevo Z2:
https://www.scan.co.uk/3xs/configurator/lg15-vengeance-pro
https://www.pcspecialist.co.uk/notebooks/recoil-II-15/
Desktop specs:
https://linustechtips.com/topic/916284-help-deciding/#findComment-11291874
19 minutes ago, CancerousNinja said:
I’m very interested at the gm501 especially because of the performance and cooling  over the other coffee lake laptop’s (gs65,Aero 15x etc..)
Cooling in thin gaming laptops is pretty much the same. Throttle under full load. Hotter inner temps, hotter surface temps and louder fan noise while under load compared to a bulky gaming laptop with 'proper' cooling system. The Zephyrus M do a better job compared to most competitors since it can be equipped with a full blown 1070N GPU.
Desktop specs:
https://linustechtips.com/topic/916284-help-deciding/#findComment-11291987
