Yesterday afternoon I just got back to my PC and it was giving me a warning about low storage, I checked and I only had a few hundred mb in my c drive, so I decided to reboot thinking maybe it would reset some things or something, unfortunately windows decided to interject and install an update during the reboot process, a few seconds after the update started it completely froze and when I tried to turn it off even the power button wasn't working, so in order to turn it off I flipped the switch on my power supply, spammed the power button for good measure, then flipped it back and hit the power switch, unfortunately however the system made no indication of booting or even posting, getting no power, so I immediately removed any hardware that could be causing a short somewhere, a wirless card, the hard drives, basically everything but the main components like GPU, RAM, and CPU. Still no luck, there isn't even a light on the Mobo indicating power, I thought maybe my PSU decided to die so I went and got an older one and wired it up, still no luck, I consider myself and avid troubleshooter and enthusiast as I have dealt with many problems similar to this but I just can't seem to solve this one, if my MOBO and PSU are bricked I may just upgrade from my i5-6500 to an i5-7640x with the new Mobo although it would take time for me to get that money. Thanks for any help!
My specs: I5-6500, GTX 980Ti hybrid, 16gb DDR4 2400, MSI gaming m3 Mobo, 1 120gb SSD boot drive and 2 1TB hard drives, a 850watt thermaltake "wicked power" PSU.
https://linustechtips.com/topic/916040-system-wont-even-post/
Any leds on the mobo? Maybe a different outlet?
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/916040-system-wont-even-post/#findComment-11237308
3 minutes ago, Klingon802 said:
Unfortunately no LEDs turned on in the Mobo and I have tried multiple power cables in multiple outlets
Other things work in these outlets right? If the mobo's power led isn't on and you know the PSU works, then it's the mobo. You could always test the PSU with the paperclip method (haven't tried this myself), but i doubt it's the PSU if you tested with another.
https://linustechtips.com/topic/916040-system-wont-even-post/#findComment-11237325
1 minute ago, userzero said:
Try booting it up without the HDD connected. Bit odd that a hard drive space issue caused all this.
I have tried booting without any of the drives as I was thinking maybe they were causing some kind of short, I think what caused this was using the switch at the back of the PSU, not the hard drive directly
https://linustechtips.com/topic/916040-system-wont-even-post/#findComment-11237327
Yeah, I have my fan and my monitors and other things connected to the same outlets and they don't have any issues
https://linustechtips.com/topic/916040-system-wont-even-post/#findComment-11237335
