Hi guys, I got the corsair h115i pro recently to cool my 8700k and it is working great except for that I cant change anything in corsair link. the cooler shows up and I can change the settings for the cooler but it does not take effect. for instance the fans are stuck to it's own profile even if i change it in corsair link and the rgb is stuck on rainbow, I wanted it to be temp based and it shows that it is on corsair link but nothing actually changes on the cooler itself. I have the latest version of the software. I also have asus aura sync since i have an asus mobo and i have msi afterburner as well as the msi gaming app for my gpu. could it be any of them conflicting with the software? or is it maybe something else? all the plugs are also in as well as the usb to mini usb connected to the pump and the pump header is connected to the pump header on the mobo and both fans to the headers coming from the pump.
https://linustechtips.com/topic/915600-h115i-pro-problems/
There is a known problem with the latest version of LINK for both the 115i pro and the 150i pro. You can either:
1. Roll back to v4.9.5.25.
2. Install iCUE (Basically CUE + LINK combined), but it is pretty buggy at the moment since it is early access.
Both worked for me with the h150i.
ps: EVGA XOC can interfere with it as well...
https://linustechtips.com/topic/915600-h115i-pro-problems/#findComment-11234918
