Overclocking Help?
Solved by kevp453,
That might just be the luck of the silicon lottery draw. Eventually you might hit a speed ceiling even though you still have thermal room, it happens. 5.0 GHz is a really good overclock for that chip and not everybody can push past it. At 1.27v it's a little higher than normal for that chip at 5.0Ghz, so you might not get more out of it. If you have to get all the way to 1.3 and not get the extra 100 MHz I'd just call it a day. See what you can do to bring the voltage down and maintain your 5.0 instead.
