I have a website that i often use, but a few days ago it has been redirecting to my local router (192.168.1.1)
If i use a proxy i can access the site, but whenever i try to connect im redirected. I have cleared my browsers cache, but that didnt fix the problem.
Any ideas?
~Judah
https://linustechtips.com/topic/91547-website-redirection-problem/
are you sure that the website isnt blocked by the router and try accesing that website on a diferent device/webrowser but still on the same router
If you tell a big enough lie and tell it frequently enough it will be believed.
-Adolf Hitler
Other browser:Still broken
Other Computer: Still broken
Pinging from router: Works
Pinging from command line: Redirects to router
Pointing browser to websites IP: works
~Judah
give your router a factory reset
-Adolf Hitler
