2 minutes ago, NABZOG said:
Need a case that would fit a 280mm cpu cooler (X62)
what do you want, tempered glass? multiple hard drive bays?. and what is your budget. imo the define R6 is the best case out there right now if you can get it.
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
https://linustechtips.com/topic/915420-280mm-cpu-cooler/#findComment-11231359
That's a lot of cases.
Any other requirements/wants so that we can try to narrow down the selection a bit?
EDIT: If you really want a list of cases that support it, then go to PCPP, add the X62 to the part list, go to pick a case with the compatibility filter enabled.
https://linustechtips.com/topic/915420-280mm-cpu-cooler/#findComment-11231363
Are you building a new PC? If so what parts/budget/country and monitor resolution/refresh rate?
X62 is an overpriced AIO
https://linustechtips.com/topic/915420-280mm-cpu-cooler/#findComment-11231384
