Custom Wooden PC Case
Go to solution Solved by KimberlyHulshof,
If you have a dremmel or hand saw you can cut out a square or circle and pre-drill some screw holes and mount the fan's that way, then all you need to do is get a fabric that is slightly translucent and allows for air movement that fits with the color scheme you want.
15 minutes ago, TrueCanadian said:
I'm trying to mount my fans to my case and i would like it nice and clean but i just cant seem to figure out a way to actually mount them, can anyone from here help me?
You can get a brackets such as these:
https://www.amazon.com/XSPC-Universal-RadStand-Radiator-Mounting/dp/B004KO9DA0
https://modmymods.com/phobya-radiator-stand-black-triple-3x120mm-bricky-38169.html
https://linustechtips.com/topic/915166-custom-wooden-pc-case/#findComment-11228774
https://linustechtips.com/topic/915166-custom-wooden-pc-case/#findComment-11229865
