Hey people of the forums, long time lurker here.
I have had a late 2012 imac for many years now. Its starting to show its age and I have decided its time to upgrade.
Budget / Location: ~$3400 USD for everything / FL Usa.
Aim: Playing VR and modern games at 1440, high or ultra.
Monitor / Peripherals: I need a new monitor but have most everything else (mouse/keeb/speakers/headphones)
Other Needs: This budget should leave some room for new games and needs to include a decent laptop for college. I was looking at something that would get the job done, such as the Acer Swift E.
Part List
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($346.89 @ OutletPC)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($34.89 @ OutletPC)
Motherboard: MSI - Z370M GAMING PRO AC Micro ATX LGA1151 Motherboard  ($165.49 @ SuperBiiz)
Memory: Team - Vulcan 16GB (1 x 16GB) DDR4-2400 Memory  ($156.99 @ Newegg)
Storage: SanDisk - Ultra 3D 500GB 2.5" Solid State Drive  ($111.58 @ B&H)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.79 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 8GB G1 Gaming Video Card  ($619.99 @ Newegg)
Case: BitFenix - Prodigy M Arctic White MicroATX Mini Tower Case  ($83.99 @ SuperBiiz)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($73.98 @ Newegg)
Monitor: Dell - S2417DG 23.8" 2560x1440 165Hz Monitor  ($369.99 @ Amazon)
Other: HTC VIVE - Virtual Reality System  ($499.00 @ Amazon)
Other: Acer Aspire E ($350.00)
Total: $2872.58
Generated by PCPartPicker 2018-04-10 20:21 EDT-0400
I would try to order as much of this off amazon for convenience and because of Prime.
The computer would need to be semi-portable, hence the microATX mobo and somewhat portable case. I am flexible on most parts of the build, this is just a preliminary parts list to see what needs to be done.
If anyone has any suggestions that would make this build better that would be much appreciated. :D
https://linustechtips.com/topic/915147-first-build-help/
just don't forget to add a SSD inside of that laptop, something like 120GB is enough for laptop that is just going to be used when out and about, somewhat like a chromebook
You can fit in a 1080ti in your PC, but you are going to be a bit above your max budget, but I would recommend it as it will be more suited towards 165hz 1440p ultra/high.
no idea if the GPU fits in that case or not, just as a warning if you do plan on getting it, that is the cheapest 1080ti and anything higher (more expensive) would be >$250 out of your budget at a minimum if I did math right
also something about waiting for next generation GPU if you are patient enough, I guess. should be Q2 2018 or something iirc
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/915147-first-build-help/#findComment-11228603
just a slight edit:
CPU Cooler: Scythe - SCNJ-4000 84.6 CFM CPU Cooler  ($39.99 @ Amazon)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($164.99 @ Newegg)
Case: BitFenix - Prodigy M Arctic White MicroATX Mini Tower Case  ($86.99 @ SuperBiiz)
Monitor: Dell - S2417DG 23.8" 2560x1440 165Hz Monitor  ($369.00 @ Amazon)
Total: $2887.69
Generated by PCPartPicker 2018-04-10 21:08 EDT-0400
https://linustechtips.com/topic/915147-first-build-help/#findComment-11228604
