Some cheap what? If you're gonna post on the forums you need to be specific or its really annoying for people trying to help
PC SPECS: i7 - 3820, 32GB GSkill DDR3 RAM, 2TB Seagate Hybrid Drive, Intel 240GB SSD, Corsair Spec Omega Case, Strix GTX 1060 6GB, Corsair H150i Pro RGB, Corsair CX850M PSU
https://linustechtips.com/topic/915102-please-help/#findComment-11228114
this is my pc https://www.amazon.ca/CYBERPOWERPC-GUA882-Desktop-FX-4300-7200RPM/dp/B01IPY2XC0/ref=sr_1_5?ie=UTF8&qid=1523396316&sr=8-5&keywords=cyberpowerpc&tag=linustechti06-20&th=1
im trying to run a gtx 1060 my processer right now is a AMD FX-4300 3.8GHz
https://linustechtips.com/topic/915102-please-help/#findComment-11228120
Just now, Snapperx said:
cheap processors.
Don't play like you couldn't understand those typos.
If you are on a forum don't assume everyones primary language is English.
I couldn't understand though :/ Not tryna be rude or anything
https://linustechtips.com/topic/915102-please-help/#findComment-11228183
26 minutes ago, tylerharding69 said:
processers
So you couldn't get the word processors out of that one? Well English is just my secondary language but I understood everything.
On the topic. If you can afford it go for the FX-8350 as @Flawizz stated.
9 minutes ago, Eliptic said:
The CPU you have should be fine
According to thebottlenecker it gives a 20% bottleneck.
https://linustechtips.com/topic/915102-please-help/#findComment-11228221
and that is a am3+
https://linustechtips.com/topic/915102-please-help/#findComment-11228269
how is this one https://www.amazon.ca/AMD-FD832EWMHKBOX-FX-8320E-8-Core-Black/dp/B00MUTWEM6/ref=sr_1_8?ie=UTF8&qid=1523401621&sr=8-8&keywords=amd+fx+8350
https://linustechtips.com/topic/915102-please-help/#findComment-11228281
You should get the 8350 for 10 CA$ more. It is more powerful and runs at 4Ghz without boost.
Here is a link to the canadian pcpartpicker https://ca.pcpartpicker.com/product/WGPzK8/amd-fx-8350-40ghz-8-core-processor-fd8350frhkhbx
https://linustechtips.com/topic/915102-please-help/#findComment-11228303
