Ryzen not boosting?
Go to solution Solved by gepowr,
9 hours ago, AdityaSaraf said:
I am currently using a Ryzen 5 1600 which is rated out of the box at 3.2ghz and boost at 3.5/3.6(can't remember sorry)
But I ran a stress test on Aida 64 today
And started up Ryzen master as I heard that it gave a more accurate temp readout
And I found out my processor was stuck at 2.8ghz
Not boosting at all
Although I'm using the stock wraith cooler
My temps were pretty low
Ryzen master showed mid 50s
Aida 64 showed high 40s
But my CPU just wouldn't boost up
I haven't overclocked
And I tried resetting the bios both from inside the bios and resetting CMOS just in case changed a setting by mistake
Try to disable amd power saving features in the bios. What's your mb? Vrm temps?
Not boosting at all
Edited by AdityaSaraf
Mentioned more details
https://linustechtips.com/topic/915093-ryzen-not-boosting/
Not boosting at all
Main Rig:
CPU: i7 4790k -> Scythe Mugen 5 (Dual Arctic P12)
MoBo: Asus Z97 Pro Gamer
RAM: 32GB DDR3 1866MHz Crucial Ballistix Sport
GPU: EVGA GTX 1080 Gaming -> Arctic Accelero Twin Turbo ii
PSU: Bequiet Pure Power 10 700W
Case: Bequiet Pure Base 600
Mobile Gaming 1: (XMG Fusion 15)
CPU: i7 9750H
RAM: 32GB DDR4 2666MHz
GPU: RTX 2070 MAX-Q
Mobile Gaming 2: (XMG P502 Pro)
CPU: i7 3740QM
RAM: 16GB DDR3 1600MHz
GPU: GTX 675MX 4GB
Ultrabook: (Dell Inspiron 13 5378)
CPU: i5 7200U
RAM: 16GB DDR4 2133MHz
GPU: HD 620
Server:
CPU: Athlon II x4 630
MoBo: Gigabyte/Dell 4GJJT
RAM: 4GB DDR3 1066MHz
GPU: Radeon HD 5450 1GB
https://linustechtips.com/topic/915093-ryzen-not-boosting/#findComment-11229432
