help choose 50$ headset
Go to solution Solved by Sfekke,
Logitech G231 is a good option.
If you do not need a microphone on your headset, I'd look into non-gaming brands they often offer better sound.
I myself use a Logitech G933 Wireless other than build quality being MC Donalds squeaky toy level bad it is amazing.
Cheaper wired options (the G231 is what my brother uses) are also amazing, do give them some time to break in. The fabric is annoying the first 2-3 weeks.
Your English is better then some here, just thought I'd throw it out here :P
im benginer and i dont know all about headset sound and quality which is best and this is my first post ask about headset,
before i have headset and it is very uncomfortable hurts my ear(cheap headset 9$ headset), and
i use headset for long time like 18hours/day, and im looking for good headset under 59$ not more,
better i buy Logitech G231 or corsair HS50 or steelseries siberia 150, or any recommend please?
and im always play PUBG and other fps and survival game, so i need headset can hear footsteps and more detailed sound
thanks you for reading and helping me
and.. sory my grammar is bad because i cant speak english
https://linustechtips.com/topic/914530-help-choose-50-headset/
When the PC is acting up haunted,
who ya gonna call?
"Monotone voice" : A local computer store.
*Terrible joke I know*
https://linustechtips.com/topic/914530-help-choose-50-headset/#findComment-11222392
I have the Steelseries Siberia 200 (formerly the v2). Its a solid headset. I may get this deleted but I did a full review of it on youtube (below). I recommend it and it's about your budget.
|| CPU: AMD Ryzen 5 1600 (@3.9GHz) || Motherboard: ASUS Prime B350 Plus || Cooler: Arctic Freezer 33 eSports Edition || GPU: EVGA GTX 1070 SC || Memory: 16GB G.Skill Trident Z RGB C16 (@2933MHz) || SSD: SanDisk 128GB || HDD: WD Blue 2TB, Toshiba 2TB, Transcend 1TB || PSU: Corsair RM550x || Case: Fractal Design Focus G || Monitor: 2x AOC 23” I2369VM IPS Full HD, Samsung 32" LED TV Monitor || Mouse: Logitech G703 Wireless || Keyboard: Cooler Master MK750 RGB (Cherry MX Brown) || Speakers: Dell Stereo Speakers || Headphones: Sennheiser HD 4.40 BT / Samsung Galaxy Buds ||
https://linustechtips.com/topic/914530-help-choose-50-headset/#findComment-11222461
3 hours ago, johan635 said:
is the earbuds logitech g231 made from memory foam? and earbuds from logitech are soft and comfortable?, how long you brother use this headset
thanks! for you awanser
I can wear my G933's all day, the G231 are the same fabric so all day is possible.
They are made from sportmesh which is fabric, soft fabric.
who ya gonna call?
https://linustechtips.com/topic/914530-help-choose-50-headset/#findComment-11222920
I am not 100% sure if you can find the HyperX Clouds/IIs in your budget, but they're fantastic. I think you can get refurbs for $60. I bought my used ones for $35. They sound somewhat low on bass and high on treble to me, but the soundstage is incredibly detailed. And they are extremely comfortable for me.
Microphone is pretty good too!
https://linustechtips.com/topic/914530-help-choose-50-headset/#findComment-11224184
