Hi Guys!
I'm new here and I would like to share my doubts, so here we go.
Here my specs:
https://valid.x86.fr/etx9kq
So I have Seidon 120v on it with Dual Fan. My CPU temps are arround 35-40C and motherboard aswell at 50% cpu fan. How am I suppose to improve my perfomance on gaming I mean what should I do in Bios settings(like going for OC is recommend or not) because I'm worried with these temps and Voltage too(not sure if is correct). It is that normal for MSI Gaming 970 temps high even in watercooler ? Should I change my Tower Case(Thermaltake Versa H23) cause front fans are at 1k rpm max speed to better air circulation ? my CPU-Z Benchmark is correct ? and last question, Should enable Core C6 state on BIOS ?
Thanks guys, sorry if I say something wrong, I appreciate ur time.
KeyKenzo.
https://linustechtips.com/topic/913927-oc-fx-8320-help/
For the record:
Your temps are fine.
Your volts are fine.
Your case is fine.
De-dust your PC if needed.
Apply good TIM (thremal grizzly, MX4, quicksilver 5, etc) if needed.
overclock the hell out of it.
Watch your VRM temps.
Do bench tests.
cheers.
https://linustechtips.com/topic/913927-oc-fx-8320-help/#findComment-11217790
