HI guys,
I have recently purchased Gigabyte's GA-AB350 gaming 3 motherboard. After the PC is built and when i have turned on the PC, All the cabinet fans along  the CPU fan everything works fine. But theirs on output form the motherboard to the monitor. and on the right corner to the motherboard theirs RED LED of the DRAM which blinks. so i don't understand  whats with the ram.
The Ram Stick I'm using is G.Skills - Ripjaws V - 8GB 2400MHZ (Single channel).
1. In the quality vendors list under 2400MHZ it only has these Modules F4-2400C15Q-32GRR, F4-2400C15Q2-64GRK, F4-2400C17S-8GDB. ( But the module number on my ram stick says F4-240017s-8GVR)
2. Does this mean if the module number isn't in the QVL it wouldn't support.?
Can somebody help.
Thank you.
VID_20180406_171659645.mp4
https://linustechtips.com/topic/913584-dram-boot-error-red-led/
