You only need a screwdriver, a knife and a scissor or snipping thingy.
The toolkit is a good idea but don't expect to use much of it for a normal build :P
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/913533-what-tools-do-i-need/#findComment-11213171
1 minute ago, Trevor87 said:
If you going to use it a lot go for it. if you only going to use it once in while you be of going to the hardware and buying you self a small screwdriver kit.
nah i sometime fix my friends computers for a bit of money and i am using my dads old screwdriver kit which is rusty and bad so probably buy this
https://linustechtips.com/topic/913533-what-tools-do-i-need/#findComment-11213175
If you can go and buy some black and some transparent cable ties (or zip ties) - and make sure the Screwdriver is magnetic
Bow down to me humans.
I can't help if you don't quote me. How am I supposed to know if you need my premium support? Now starting at £399.99 a year.
Also, be a sport and mark the correct answer as the correct answer. It will help pour souls in the future when they are stuck and need guidance.
"If it works, proceed to take it apart and 'make it work better.' Then cry for help when it breaks." - Me, about five minutes ago when my train of thought wandered.
Remember kids, A janky solution is still a solution.
https://linustechtips.com/topic/913533-what-tools-do-i-need/#findComment-11213187
You know these twistable cable ties you always get on brand new cable? Save those and use them for cable management. They're better than zip ties cuzz you can't open zip ties without breaking them. Really useful stuff.
or while you're at it. Buy some velcro cable ties.
CPU: AMD 3800X GPU: GTX 1080 Ti RAM: (16GB) 2x Corsair 8gb DDR4 3200Mhz Drives: SanDisk 240GB SSD, Samsung 500GB SSD, WD 1TB HDD
Motherboard: MSI X470 Gaming pro plus PSU: Gigabyte 650 watt Monitor(s): 27 inch AOC 1440p
https://linustechtips.com/topic/913533-what-tools-do-i-need/#findComment-11213194
Have to say - better Idea then mine :)
https://linustechtips.com/topic/913533-what-tools-do-i-need/#findComment-11213204
47 minutes ago, Fadedboy said:
I am soon gonna make my first ever gaming pc and i would like to know if there are any good tool kits that are good for this task. I am considering buying the ifixit pro tool kit. I dont have a budget and i live in austria.
Anti static thing?
https://linustechtips.com/topic/913533-what-tools-do-i-need/#findComment-11213254
i bought a kit on amazon thats a lot like the ifixit kit for way cheaper and its worked great the past few months ive had it. i dont remember the exact name but i know it's made by ORIA. im in america so i dont know if this is available where you live but it's around 25 USD on amazon.
https://linustechtips.com/topic/913533-what-tools-do-i-need/#findComment-11213337
You don't actually need much for putting together a PC these days. It's pretty much snap together, aside from sometimes a screwdriver if the case doesn't have the thumb twisty screws. Anti-static mat and wristband is a good place to start.
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
https://linustechtips.com/topic/913533-what-tools-do-i-need/#findComment-11227374
