I’m building a PC in a couple months, I need some help on what to get for $1000 or less. I was looking at a 1050ti and a i5 7400 with 16gbs of RAM, should I keep these core components the way they are or should I change some things? Also what are some good budget cases/CPU coolers/motherboards for these parts? Thanks :)
https://linustechtips.com/topic/913311-first-pc-build-under-1000/
BUILD SOMETHING LIKE THIS...
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($175.77 @ OutletPC)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($74.39 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($164.99 @ Newegg Business)
Storage: SanDisk - SSD PLUS 240GB 2.5" Solid State Drive  ($69.89 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.79 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1060 6GB 6GB AORUS Video Card  ($394.88 @ OutletPC)
Case: Cooler Master - MasterBox Lite 3.1 MicroATX Mid Tower Case  ($37.99 @ Amazon)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($38.99 @ Newegg)
Total: $1016.69
Generated by PCPartPicker 2018-04-05 15:35 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
Total: $1016.69
No need for OP to spend an extra $150 relative to the 1060s MSRP
You can get this exact build, get a z370 + 8700k, and get a used 980/980ti, and get a better case like a s340 as well as a tier 1-3 PSU
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
Fr ur kind info....980ti's r currently going around fr $400-500...
U would be lucky if u find it below that price range....
I recently sold one of my 980ti fr about $500
Moreover...I HV lately seen that most of the used 980ti hitting the market r coming from mining rigs....so they r not worth it....at that price pt..
Moreover....OP cn wait fr the new generations of ryzen CPUs launching in this month.
SSD TIER LIST
CPU - Ryzen 7 3700X
Are you missing half your keys or somethings xD  jk
you can easily find a 980ti used on locals for 250-300
You're right, I totally forgot, he should wait for those 2nd gen CPUs
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
Damn...that crypto thing hv brought the prices of GPUs at their ultimate peak...
No sub $400 deals fr 980ti at my place
SSD TIER LIST
CPU - Ryzen 7 3700X
