I had recently started building a pc. I was just wondering if I needed anything else, or if anything isn't compatible.
GPU: MSI GTX 1050 Ti Low Profile       CPU: Ryzen 3 2200g       Ram: Ballistix Sport 8gb ddr4          Mobo: MSI B350 gaming pro     PSU: Rosewill Glacier 600W
Case: Cooler Master Masterbox Lite 3.1      OS: windows 10 home         internet: Cat6 100ft
https://linustechtips.com/topic/913032-self-built-pc/
MSI AM4 motherboards are not as good as the competition. The PSU is quite bad quality. You need some storage (SSD/HDD).
This is what I would do (more or less):
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor  ($99.88 @ OutletPC)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($74.39 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-3200 Memory  ($94.99 @ Newegg)
Storage: SanDisk - SSD PLUS 240GB 2.5" Solid State Drive  ($69.89 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($43.21 @ OutletPC)
Video Card: Asus - GeForce GTX 1050 Ti 4GB Phoenix Video Card  ($204.98 @ Newegg)
Case: Cooler Master - MasterBox Q300L MicroATX Mini Tower Case  ($38.99 @ SuperBiiz)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($26.99 @ Newegg)
Total: $653.32
Generated by PCPartPicker 2018-04-04 20:47 EDT-0400
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/913032-self-built-pc/#findComment-11208427
