I am planning a PC build and I already have the Noctua NH-D15. I plan to build on the ASUS ROG STRIX Z270E GAMING mobo. I also what to get 64 GB of corsair vengeance ram. https://www.amazon.com/dp/B072JYJFB9/?coliid=I13QAYGHTDREFJ&colid=1OYHWQKD2O61D&psc=1&ref_=lv_ov_lig_dp_it      If you could get back to me that would be great.
https://linustechtips.com/topic/912512-cpu-cooler-clearance/
According to noctua the cooler will fit (https://noctua.at/en/products/cpu-cooler-retail/nh-d15/?tab=comp#socket_3297_manuf_30), but clearance for the memory is 32mm under the fan, and the ram you have linked is 46mm, so it won't fit.
CPU: i7 3770K | MB: EVGA Z77 FTW | RAM: HyperX Savage 2400Mhz 16GB | GPU: R9 280X Toxic | Cooler: Scythe Fuma | PSU: CoolerMaster B600
SSD: Crucial MX300 525GB | HDD: Seagate Barracuda 7200.12 500GB - Toshiba DT01ACA300 3TB
https://linustechtips.com/topic/912512-cpu-cooler-clearance/#findComment-11203123
The heatsink supports ram up to 64mm tall with the fan raised so it should fit fine. The fan can also be moved to the other side in pull.
Moved to Air Cooling.
https://linustechtips.com/topic/912512-cpu-cooler-clearance/#findComment-11204673
Fair point, although it will make the heatsink 180-197 mm tall, so case clearance might be an issue.
https://linustechtips.com/topic/912512-cpu-cooler-clearance/#findComment-11205422
