exclude certain static IP addresses from using VPN
Go to solution Solved by mpsparrow,
After messing around with it more I figured out the best way to go about it. Instead of excluding IP addresses I was able to include a range of IP addresses. Then I set my IP Pool from 192.168.1.2 to 192.168.1.126. Then when I want a computer to not be on the VPN I just set a static IP address for it above 192.168.1.126 and it will not be on the VPN.
The other day I finally got around to setting myself up with a VPN. I set it up on my Asus RT-AC68U which is running the latest Asuswrt-Merlin 384.4_2 firmware.
So my issue is I want to set it up so that I can exclude certain static IP addresses in the network from using the VPN. I messed around with redirecting internet traffic using policy rules but I can only seem to add IP addresses to use the VPN instead of exclude just one or two IP addresses from using the VPN. How does one go about simply excluding a static IP address from using the VPN?
