Help on a level on code.org
Go to solution Solved by Youbetternot,
NVM I GOT IT :D
So umm I am on level 87 on Code.org and I looked at the "Cheats" it had a block called draw a triangle with length, but on the actual one it has just draw a triangle? What do I do?
Actual
Cheat sheet
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/91128-help-on-a-level-on-codeorg/
Actual
Cheat sheet
OT:How old are you O.o
Just HELP ME!
NVM I GOT IT :D
