Raspberry pi 3 B+ Case compatible?
Solved by TheGlenlivet,
27 minutes ago, voylin said:Is the new Raspberry Pi 3 B+ compatible with older generation cases? I can't find much information about this.
This is the case I would buy for it but I'm not sure if it will fit
https://www.alternate.be/Joy-IT/Behuizing-voor-Raspberry-Pi-2-3-B+/html/product/1269170?event=search
It's the same size as the old 3b. The only difference is a few chips on the board in different locations. If you buy a heat sink for the CPU you won't be able to close the lid on some cases. FYI.
3B+
3B
