Hello
my cpu is ryzen 5 1600 . mobo asus prime b350m-a
i oc`d my ryzen to 3.7
offset mode +
used 0.16250
stable now
i didnt understand offset mode i want oc now to 3.8
what voltage i should use 0.17 ?
I do not know the key to success, but the key to failure is trying to please everyone
https://linustechtips.com/topic/910097-oc-with-offset-mode/
offset mode, from my understanding is just, that the cpu takes a automatic (or static idk tbh) voltage and your offset is the amount it can wiggle with that, so if you offset is 0.16sth it can go up and down by that amount, personally i always use fixed voltage so
    Quote=Reply      Feel free to tag me or sth if you have questions about Liquid Metal :) ROCKETS ARE LIFE        My current build:
CPU: I7 6700k@4.7Ghz 1.31sth V; Liquid Metal (Thermal Grizzly Conductonaut) | Cooler: Corsair H100iv2 | GPU: HIS R9 390 | Motherboard: Asus Z170-A | RAM: 16GB 2133Mhz HyperX FuryX | Storage: 1x 250GB Samsung 960 Evo 1x random 4TB 7200RPM HDD | Case: Lian Li Alpha  550W | PSU: Corsair RM650i | Misc.: 6x Lian Li 120mm Bora RGB Fans
My Build Log:
https://linustechtips.com/topic/910097-oc-with-offset-mode/#findComment-11179854
9 minutes ago, Fahad ALme said:
Hello
offset mode +
used 0.16250
stable now
Read this. It should answer your questions.
https://rog.asus.com/forum/showthread.php?2162-Overclocking-Using-Offset-Mode-for-CPU-Core-Voltage
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/910097-oc-with-offset-mode/#findComment-11179869
socket cooler cpu burner 5aba5e268b8d9_DesktopScreenshot2018_03.27-18_03_46_31.thumb.png.233145334445a00e9d1bf4d6d8b6d6d7.png
5 min test cpu usage 99% cpu temp 76 no more with 5 min
did that mean stable
https://linustechtips.com/topic/910097-oc-with-offset-mode/#findComment-11179985
