2nd Upgrade Help
Go to solution Solved by Herman Mcpootis,
1 minute ago, OrangeBlorange said:
So if I have 4GB x 2 ram its completely fine to put another 4GB x 2 ram in the other 2 slots?
I just don't want to put my money in until I completely understand.
Thanks alot.
yes, most of the time mixing ran modules will work. I'd get 1x8gb for upgradibility.
Hello,
I am about too upgrade my PC again after my 7 year old hard drive randomly decided to die.
I currently have:
  • i7 3770 (stock)
  • GTX 780ti
  • 8GB of ram (7 year old)
  • Dead hard drive (7 year old)
  • Random Alienware x51 motherboard from 2011-2012 which is still alive surprisingly.
What I am to upgrade:
  • Samsung EVO 250gb SSD
  • WD Mainstream 3.5" 1 TB Hard Drive
  • G.Skill - Aegis 1 x 8GB DDR4 1333MHz Ram (Will be 16 GB when I can afford it)
  • Hyper 212 Evo (Processor Fan)
  • AS Rock a77 Extreme 4 (Still in box 2-3 years old)
Is this feasible? Please tell me if something is not good enough or needs changing. I play games like Pubg, Battlefield 1 etc..
Thanks,
https://linustechtips.com/topic/909939-2nd-upgrade-help/
if you can just add in your new ram don't completly replace it.
get a 500gb SSD if you can.
get a 2-3tb as those are more storage per $.
don't change mobo or add cooler unless its a K model and you want to dump money into an old platform.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/909939-2nd-upgrade-help/#findComment-11178238
ZcanKal is correct. Your motherboard & cpu only works with DDR3 ram. Depending on how your old ram is setup ( 2x 4 gb sticks or a 8 gb stick) you can just add to your existing ram. Just make sure the ram capacity sizes are all the same and running the same speed.
https://linustechtips.com/topic/909939-2nd-upgrade-help/#findComment-11178273
28 minutes ago, OrangeBlorange said:
Hello,
I currently have:
  • i7 3770 (stock)
  • GTX 780ti
Thanks,
The Z77 chipset doesn't work with DDR4. You'll be wanting DDR3 for that
https://linustechtips.com/topic/909939-2nd-upgrade-help/#findComment-11178292
So I can add upon the ram? Is the ram I have not really old  and beaten up? Sorry I am out the loop with computing components now. It is in 4 GB slots x 2 in my current mini ITX motherboard.
https://linustechtips.com/topic/909939-2nd-upgrade-help/#findComment-11178302
22 minutes ago, ZcanKal said:
a 3770 won't accept DDR4, not electrically, but it physically just won't fit.  Buy a used DDR3 stick of preferably the same kind as your old stick.
Hi,
Could I just overhaul it with 16 GB of this RAM?
Corsair CMZ16GX3M2A1600C10 Vengeance 16GB (2x8GB) DDR3 1600 Mhz CL10 XMP Performance Desktop Memory Kit Black
https://www.amazon.co.uk/Corsair-CMZ16GX3M2A1600C10-Vengeance-Performance-Desktop/dp/B006EWUO22/ref=sr_1_3?ie=UTF8&qid=1522110637&sr=8-3&keywords=ddr3+ram+16gb
https://linustechtips.com/topic/909939-2nd-upgrade-help/#findComment-11178309
If everything is working just add 2x 4 gb sticks. The new motherboard you are getting looks like it has 4 ram slots.
https://linustechtips.com/topic/909939-2nd-upgrade-help/#findComment-11178312
https://linustechtips.com/topic/909939-2nd-upgrade-help/#findComment-11178316
This is what my new basket looks like. Thanks guys!
https://gyazo.com/88b08507e12618af6a26e82fe748495b
Have fun with your new build. Remember you can use https://pcpartpicker.com/ to help you get the best deals on your parts or compatibility in the future. It will pick from multiple retailers like Amazon, etc.
https://linustechtips.com/topic/909939-2nd-upgrade-help/#findComment-11178336
get a 7200rpm drive instead of that, and if the MX500 is at a similar price or cheaper then get that instead. one 8gb stick paired with the one you already have is enough.
https://linustechtips.com/topic/909939-2nd-upgrade-help/#findComment-11178352
CPU Cooler: ARCTIC - Freezer i11 CO 74.0 CFM CPU Cooler  (£20.22 @ Amazon UK)
Memory: Kingston - HyperX Fury Black 8GB (1 x 8GB) DDR3-1866 Memory  (£54.97 @ Amazon UK)
Storage: Crucial - MX500 500GB 2.5" Solid State Drive  (£108.83 @ Amazon UK)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£47.94 @ Aria PC)
Total: £231.96
Generated by PCPartPicker 2018-03-27 01:57 BST+0100
https://linustechtips.com/topic/909939-2nd-upgrade-help/#findComment-11178368
Total: £231.96
Thanks alot.
https://linustechtips.com/topic/909939-2nd-upgrade-help/#findComment-11178389
Thanks alot.
https://linustechtips.com/topic/909939-2nd-upgrade-help/#findComment-11178392
