12 minutes ago, lequsha123 said:
I’m trying to put together a hardline water cooling build and was wondering what the best tubing brand/size was. Also what kits are best. Any suggestions?
The size is really up to you and what looks best, as for brands EKWB (waterblocks) and Bitspowers (fittings) would be the two top ones for watercooling.
-Moved to Liquid and Exotic Cooling-
https://linustechtips.com/topic/909885-hardline-water-cooling/#findComment-11177661
