16 minutes ago, vikkiG said:
SHUT UP YOU BIG NOOB ;P
Windows 8 might actually not be supported.
You might need to update onto Windows 8.1.
A lot of support was dropped for Windows 8, as MS was trying to push people AWAY from it.
Even AMD dropped their driver support for Windows 8 -- it was either Windows 7, 8.1, or 10.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/909210-cant-connect-to-printer/#findComment-11171434
