Story time:
A stink bug got into my fan, which not only smells as great as you'd think but also upgraded my fan with a jet engine volume upgrade any time the machine is under load.
Help time:
So I don't really know what I'm looking at.  The fan seems to have some sort of heat sync for the water cooled processor.  I haven't built a machine in awhile and I'm not sure what it is I'm looking at here, or what if anything special I need here.
Any information I can provide I'm happy to.  If possible, I'd prefer amazon links (since they donate to MS society when I make purchases).
The 2nd image is the side of my case, I'd like to add an additional 2ndary fan there to help with some woosh.  I'm figuring that can be a fairly generic smaller fan.  120mm appears to be the correct size for that.
I'm also thinking for best airflow I'd want them both pointing out.
Appreciate any help, thank you kindly.
https://linustechtips.com/topic/907950-help-w-fan-replacement/
That is the fan for your All in one cooler, you'd want a static pressure fan for the replacement. I would recommend Akasa Piranha or Viper fans, if you can afford them also Noctua NF-F12, there's also some corsair ones I can't remember the name of, which country are you from as I wouldn't want to give you the wrong links.
For the side panel, air flow is more important, Noctua NF-S12A or their redux line. Corsair air flow fans or ML series. I'm forgetting alot of companies so hopefully other chime in.
Wraith/Main Rig: AMD Ryzen 7 5800X3D | DeepCool AK620 | ASRock X570 Steel Legend | Micron Workstation ECC 64GB | XFX Speedster SWFT 319 Radeon RX 6800 XT 16GB | Topping D50s+A50s+PA3s | Seagate FireCuda 520 NVMe 500GB, Samsung 860 EVO M.2 1TB, Samsung 970 EVO Plus NVMe 2TB, HPE SSD 1.92TB, Toshiba X300 4TB, Seagate SkyHawk 4TB, WD Blue 4TB, HPE HDD 8TB | LG GGW-H20L Bluray-RW, Pioneer DVR-220LBK DVD-RW | HP NC550SFP 10GbE | Super Flower Leadex II Gold 750W | CoolerMaster MasterCase MC500P - Ghost/Test Rig: AMD Ryzen 7 1800X | Scythe Mugen 5 Rev.B | Asus ROG Strix X370-F | Crucial Ballistix Red 16GB | ASRock Intel ARC A770 Phantom Gaming D 8GB | Asus Xonar D2X | Crucial MX500 250GB, Seagate BarraCuda 500GB | SAMA Forza 750W Gold | Antec GX200
Phantom/Win98 Rig: AMD Athlon XP-M 2500+ | Arctic Cooling Copper Silent 3 | ASRock K7S41GX | Elixir 512MB | ATI Radeon 9800 XT 256MB with ATI Silencer 3 Rev.2 | Aureal BA88DL30A-01 Vortex 2 | Seagate Barracuda 160GB | LiteOn IHDP118-18 DVD-Rom | Samsung FDD | Ccivo 300W | CiT S008B - Parvati IV/Home Unraid Rig: Dual AMD Opteron 4184 | 2x Noctua NH-U12DO A3 | Supermicro Aplus H8DCL-i | Samsung ECC 32GB | Matrox G200eW 16MB | Kioxia Exceria G2 1TB, HPE Seagate Exos 4TB, 2x Seagate Barracuda Green 2TB, 2x Toshiba E300 2TB, Seagate SkyHawk 2TB, 2x Samsung Spinpoint F4EG 2TB, Seagate Essentials 1TB, WD Green 500GB | Dell Perc H200+H310 HBA, HP NC550SFP 10GbE | Cooler Master MWE v2 850W | Corsair Obsidian 750d Full Tower - Behemoth12/Second Unraid Rig: HP Microserver G8 | Xeon E3-1220L V2 | Intel C204 | Hynix ECC 16GB | Matrox G200eH 16MB | WD Green 500GB NVMe |
https://linustechtips.com/topic/907950-help-w-fan-replacement/#findComment-11159168
11 minutes ago, DaBethum said:
USA
In that case as you prefer Amazon, I'll redact my recommendation of Akasa, for whatever reason they are just as pricy as Noctua's and only sold my third party sellers (which is very much not the same here in the UK)
Anyway, here's a Noctua NF-F12 for your AIO cooler, if you don't like the colour then maybe Corsair's SP 120.
For the case fan you can go with a Noctua NF-S12A FLX or cheaper Noctua Redux NF-S12B, there's also Corsair's AF 120. If you want cheaper then most Antec, Silverstone or CoolerMaster fans will probably do.
I personally have only used Akasa, Antec, Arctic, Corsair and Scythe fans myself. The other recommendations are based on reviews I've seen before so they should be good fans if they are in your budget, sorry I couldn't be more useful but the prices are all over the place on Amazon for America, over here in the UK for example Akasa are a lot cheaper then Noctua and Corsair fans can be more affordable depending on website. Antec and Arctic can be rather cheap but with Antec you'll have to set speeds yourself on the good ones which can be a pain depending where they are and Arctic specialise in affordable quiet fans.
https://linustechtips.com/topic/907950-help-w-fan-replacement/#findComment-11159240
What are your specs and temps?
What's your budget?
https://linustechtips.com/topic/907950-help-w-fan-replacement/#findComment-11159619
