7 minutes ago, soumyagent47 said:
MSI afterburner overlay just showing temperature any help?
You talking about the on screen display while in games or in the app itself?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/907616-msi-afterburner-problem/#findComment-11155870
10 minutes ago, soumyagent47 said:
yes please help
you still didnt answer my question.. .which is it?
Community Standards
"Beast Mode"
https://linustechtips.com/topic/907616-msi-afterburner-problem/#findComment-11155911
so it doesnt look like this? or is the information displayed in game to you...
Community Standards
"Beast Mode"
https://linustechtips.com/topic/907616-msi-afterburner-problem/#findComment-11155970
ok so the OSD. You need to go into your settings and enable it in the monitoring section. Go and select the variables you want monitored then right below it there is a check box that says Show in On-Screen Display. In order for this to be enabled, you need to make sure the graphing feature is enabled which will be shown with a dark check mark next to the variable.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/907616-msi-afterburner-problem/#findComment-11155995
Thank you for your help
https://linustechtips.com/topic/907616-msi-afterburner-problem/#findComment-11156059
