Yo, context- Have a 1700x/1080ti a nice set of nice B&W speakers a Kef subwoofer and now a TV that was purchased the early part of 2012 and at 1080p/60hz 48" its not cutting the mustard anymore.
everything is top spec, and the TV is meh.
so id like:
4K
60Hz(or more if possible)
50" or more
as dumb as possible- ie dont need webos/smart tv, just a panel that has pixels on it,
UK only pls.
Speakers- couldn't care less if it has them or not they wont be used.
as little input lag as possible(i am fully wired RE mouse/keyboard.)
sub 600pounds if possible,
cheers all.
are there anythings i need to look out for ie OLED/Qdot/etc?? any manufactureres that i need to avoid??
https://linustechtips.com/topic/906576-htpc-tv-help/
