Hi, I just put a Seagate Barracuda 2TB HDD into my new build, it is a meshify C case, using the front and back fans it came with and a Cryorig H7 for an i5 8400. The GPU is an Asus ROG Strix 1060.
Hopefully someone will be familiar with this case and where the HDD slots are, do I need to do anything else other than just pop the drive in like I have and forget about it?
https://linustechtips.com/topic/906555-cooling-for-an-hdd/
The hdd should be fine without any additional cooling. You can use software like CrystalDiskInfo to check on temps and drive health after leaving the system running for a while if you're worried: https://crystalmark.info/en/software/crystaldiskinfo/
https://linustechtips.com/topic/906555-cooling-for-an-hdd/#findComment-11145715
