Hey everyone,
So recently I've been having a problem and I can't really figure out what's going on.
If I plug-in a hard drive via usb 2.0 and transfer files, everything works fine.
If I plug-in a hard drive via usb 3.0 and transfer files, it disconnects all usb devices connected to the computer until the file transfer stops, and then they all reconnect again.
I've been searching all over for a solution to this and can't even remotely figure out what could be causing this.
If someone could help that would be awesome. :)
https://linustechtips.com/topic/906370-usb-30-problem/
What Mainboard? Try to reinstall ur USB drivers
|| CPU: I7 6950X @4.6 (1.35V) || Cooler: CUSTOM EK LOOP || Motherboard: ASUS RAMPAGE V EDITION 10
|| GPU: 2x Vega 64 Strix OC @1762 / 1100 MHz || Memory: 16GB G.Skill Royal RGB 3200 Mhz ||
HDD: Segate Barracuda 3TB || SSD: Samsung 970 Evo 512 GB || PSU: Corsair HX 1200 W || Case: Fractal Design Define R6 Gunmetal || Fans: Corsair HD120 (x4) / BeQuiet Silent Wings 3 (x4) || Monitor: ACER XF27HU ||
Second Monitor: BENQ RL2455HM || Mouse: Logitech G502 Pretus Core || Keyboard: Logitech G810 Orion Spectrum || Headphones: Sennheiser IE80 ||
        Buildlog expirience swapping to x99:
https://linustechtips.com/topic/906370-usb-30-problem/#findComment-11143825
Are you plugging it into the same USB 3 port each time?  Or do you have several USB 3 ports that you are switching around using.  As stated -- it could be a driver issue -- or it could be something physically lodged inside the USB 3 port on your motherboard.  I've seen a similar situation when there was a small metal fragment inside the USB port on a laptop.  Connect/Disconnect.
https://linustechtips.com/topic/906370-usb-30-problem/#findComment-11144026
