Already found my ratio and full voltage amount under load. I tested under override mode.
I want to be able to however, in idle have the voltage and clock go down.
My problem is i can't figure out how to do that. Setting an adaptive mode doesn't seem to work or I'm not using it properly
While in override mode, i set the voltage to 1.295. I want this not go above 1.295. (it currently is and i know 1.295 is stable for 100 percent load)
What settings should i set?
MOBO: msi Z730 pro Carbon
https://linustechtips.com/topic/905997-8700k-overclock-help/
Enable c-states, speedstep and EIST.
Desktop benching:
https://linustechtips.com/topic/905997-8700k-overclock-help/#findComment-11140023
