My taskbar width broke, help
Go to solution Solved by Offline Research Kangaroo,
2 minutes ago, Crunchy Dragon said:
On Windows 7, you can adjust the width of the taskbar by hovering the mouse right on the edge until the cursor becomes a line with two arrows on either end, and then you can click and drag to change it.
i figured it out, for some reason this option got enabled.everythings back to normal now.
also yes i know i can drag the taskbar width ;)
i clicked something random on the taskbar and now its about 20% wider than it was before and i cant get it back to the smallest size
image.png.f6faf4458a50836d9a43a67d830a6717.png - i think it has something to do with that thing (if i drag it up, my files appear and i cant remember it being there before)
IGNORE THE NEXT 2 PICS - for some reason it wont let me remove them
https://linustechtips.com/topic/905723-my-taskbar-width-broke-help/
