So when i open an app or program it doesnt auromatically or show the windows mode, it always stay on the task bar while orange color is blinking on it. I want it to open immediately and not just stay on task bar so i need to click on it again just to show the window mode. Apps doing like this is f.ex. Blizzard desktop app. Any help pls.
sorry for bad english.
https://linustechtips.com/topic/905527-problem-when-opening-apps-or-programs/
6 hours ago, LoGiCalDrm said:
Does this happen on all software? Check if you have selected to start software minimized in settings.
Hi, no it doesnt happen on all software just some. I will try to check the setting when i get home and hold an update about this.
You've probably then just set those software to start minimized.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
