OK, so I've owned my PC for around 9 months now and last week I booted up my PC to no avail everything booted, fans everything but no display, I noticed the EZ debug light on my motherboard was showing a CPU error so I turned my PC off pulled my cooler off and cleaned and re-sat my CPU, turned my PC back on and still nothing and still error light, I re-sat my ram 1 by 1 and nothing, I reset the cmos and nothing, so I left my PC running while I went to work and when I got back there was no CPU error light and my PC worked fine...the next day the CPU error debug light was back and nothing would work, at some point the light went away and the computer worked and now this morning the light is back and my PC boots up, fans spinning everything but the CPU debug light is on an my PC won't display anything...
PC specs; I5-7600
Rx 480 8gb
B250 gaming m3 motherboard
8gb corsair vengeance lpx 2x4gb
Cryorig h7
120gb ssd
500gb hdd
Thermaltake smart 650w psu
Thank you in advance!!!
https://linustechtips.com/topic/905348-cpu-error-debug-light-no-display/
Have you tried checking if everything's plugged in properly? maybe something got knocked loose when you pulled off your cooler. Also make sure that you didnt tight the cpu cooler too much. also maybe try another cpu / test your 7500 on another mobo.
Command Centre
CPU - Intel® Core™ i7-6950X Extreme Edition | CPU Cooler - EVGA CLC 280MM | Motherboard -  ASUS X99-E WS/USB 3.1  | RAM -  Corsair Dominator® Platinum Series 64GB (8 x 8GB) 3200Mhz | Graphics Card (CrossFire) - XFX Radeon RX Vega 64 8GB HBM2 - XFX Radeon RX Vega 64 8GB HBM2  | Power Supply - Corsair AX1200i | Storage - WD Caviar Black 4TB (WD4003FZEX) | Sammsung 960 Pro M.2 SSD 512GB  | Case - In Win 909 (Silver)
Battlestation
CPU - Intel® Core™ i7-8086K Limited Edition | CPU Cooler - EVGA CLC 280MM | Motherboard -  EVGA Z370 Classfied K  | RAM -    | Graphics Card - [No GPU] AMD Navi? | Power Supply - EVGA SuperNova 1000 T2 | Storage -  | Case - In Win 303 (Black)
Operating System - Microsoft Windows 10 Pro | Peripherals - Filco Majestouch-2 NKR 104 ASCII with Cherry MX Red Switch | Logitech G Pro Tenkeyless Mechanical Gaming Keyboard | Logitech G903 Wireless Gaming Mouse | Microsoft Xbox One Elite Controller | Audio - Røde NT-USB | Sennheiser GSX 1000 | Sennheiser HD 599
Yeah I've checked all the cables, would tightening the CPU cooler cause this, I may try loosening it slightly I guess but given that it's worked on and off for the past week I don't on now if that would be the cause, because it hasn't been working and I haven't touched it and then it will randomly start working again
Just now, Joewalk11 said:
Nah,  this is my first ever proper PC and so these parts are the only modern parts I own
What about friend's PC?
So far all I see is that there's an issue with the CPU or it could be RAM. Did you try booting the system with only one stick?
Could you clarify this poart? By running do you mean you simply turned it on despite it not showing anything on display, then when you got back it worked?
I've read something about the backplate of the cooler shorting with the motherboard when tightened too much. I've had it happened to me aswell before with my i5 4570 rig. I think I was using a Noctua L9i/Cryorig C7 and i tightened it way too much that my PC wont boot.
Command Centre
Battlestation
Yeah so basically my PC was turned on with all the fans and everything running but still no display and the CPU debug light was on and I went to work,  I got home and the PC was in the main windows hoke screen with no CPU error
Ill see if I can use a friend PC to test my CPU and yes I've tried booting with one stick of ram, each stick I'm every slot and I still get the debug light and no display
Perhaps there's a problem with connection. Can you check the pins on the CPU? Maybe some are bent.
I've checked the pins on the motherboard many times and they all appear to be perfectly fine, it just doesn't make sense that one day it randomly wouldn't boot and now every second or so day it will work no problem until turned off and then the debug light comes back and it doesn't work
I've just loosened the backplate to what seems reasonable and I still get the CPU debug error, I didn't think this would be the case because it suddenly wouldn't work one day,  I hadn't touched the CPU cooler for months before this incident
@Joewalk11 That's just it, you need to test your CPU in naother system. And if that doesn't work, you need to check the motherboard:/
I know it might be hard to achieve, but it is something that you need to do.
Perhaps a local tech store can help you out with that for a small price?
Yeah, I've got a couple around, guess I'll have to head in some time to see if they can figure out what's wrong, thanks!
Well if it works not I wouldn't worry. It could just be a cmos or UEFI bug
PC Specs:
CPU: Intel Core i7-12700K 3.6 GHz 12-Core
CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z690-E GAMING WIFI ATX LGA1700
RAM: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-5200 CL40
Storage: Boot Drive: Samsung 960 Evo 250GB M.2 NVMe SSD
               Other Storage: Mass Storage: Western Digital Caviar Blue 1TB 7200 RPM, Western Digital Caviar Blue 2TB 5400 RPM, Scratch Disk: Intel X25-E SSDSA2SH032G1 32GB SATA II SSD, Backup Drive: Seagate ST3160318AS 160GB HDD
GPU: Asus GeForce RTX 3080 Ti 12 GB ROG STRIX GAMING OC
Case: Corsair 5000D AIRFLOW ATX Mid Tower
PSU: Silverstone Strider Platinum S 1000 W 80+ Platinum Certified Fully Modular ATX
OS: Windows 11 Pro 64-Bit
Monitors: Primary: Samsung S34E790C 34" 3440*1440 60 Hz UWQHD; Secondary: LG 34UM58-P 34" 2560*1080 75 Hz UWFHD; Tertiary: BenQ GL2460 24" 1920*1080 60 Hz FHD
Keyboard: Corsair K70 Mk. 2 RGB Gaming Keyboard - Black
Mouse: Corsair M65 Pro RGB FPS Gaming Mouse - Black, Logitech MX Master 3
Headphones: Corsair VOID PRO Surround Cherry 7.1ch
Speakers: Logitech Z213 7W 2.1ch
Laptop:
Asus Zenbook Pro 15 (UX535Li-E2018T) with Intel Core i7-10750-H 12MB @ 2.60GHz (Turbo @ 5.0 GHz), 16GB (2 x 8GB) DDR4 2933 MHz SODIMM and Intel(R) UHD Graphics; NVidia Geforce GTX 1650-Ti with Max-Q Design, using WDC NVMe PC SN730 SDBPNTY-1T00-1102, on a 96-Wh battery
NAS Specs:
Make & Model: QNAP TS-1277
CPU: AMD Ryzen 5 1600 @Stock
Hard Drives: x8 WD Red 2TB
SSDs (2.5"): x1 Samsung 850 Evo 250GB V-NAND (cache drive)
M.2 SSDs: None
RAID Configuration: RAID 6 (excluding SSD)
Total Storage: 12TB
Expansion Cards: None
  • 2 years later...
