My laptop's GPU (GTX 260M) had a problem and it waas causing my laptop to shut down immediately after the BIOS, so I decided to replace it. I found a Quadro FX 2800M on eBay but when I installed it, the laptop at the beginning refused to power on, but after a few tries it powers on but with a black screen, no BIOS, and the it turns off. Can someone tell me if the Quadro is compatible with my laptop or what might be the cause of the problem?
Thanks in advance!
CPU: AMD FX-6100 Black Edition @3.9GHz GPU: XFX 7970 DD (1062/1520 MHz) MOBO: ASUS Sabertooth 990FXA(1st Revision) RAM: Corsair Vengeance 16GB @ 1333MHz Storage: Corsair Force 3 120GB(Boot) + WD Green 1TB(storage) PSU: FSP AURUM 600W(80+ Gold) CPU Cooler: Cryorig M9a  Case: NZXT Tempst 410 Elite(Mid-Tower) Mouse: Logitech G602(Manufacturer Refurbished) Keyboard: Noppoo Choc Mini(Cherry MX Blue) AUDIO:Sennheiser HD 598+ASUS Xonar DGX Monitor: LG M2280DF 21.5" 1080p(TN-75Hz)
https://linustechtips.com/topic/904268-help-with-laptop-gpu/
