So, im trying to fresh install windows 7 on a new pc (msi b350m motherboard) via USB but it continues to block me during the installation due to missing appropriate USB drivers... I tryed with 2 different iso files, different usb sticks and different programs to prepare the sticks. I even tryed to manually add some more recent usb drivers to the stick but nothing seems to cahnge (both with 2.0 and 3.0 ports). I managed to install win10 so i have access to the hdd and all the other stuff, any suggestion?
https://linustechtips.com/topic/904186-problems-installing-win7/
2 minutes ago, Smooky97 said:
Y I know 10 is definitely better but it just triggers me, can't deal with that OS... Ty btw I'll try your solution and let u know
You haven't answered my question. From the looks of it you have a NVMe drive and Win7 is missing the drivers for it.
If you're using Ryzen, i'd highly recommend using Win10 :/
Just tag @ChatDaw so I can answer as fast as possible.
2 minutes ago, Doomed83 said:
Normally this happens when the windows installer can't detect the storage device you want to install on. If using an NVMe drive or a raid controller for instance.
What drive are you trying to install on?
Just a standard ssd
What processor do you have?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
1 minute ago, Doomed83 said:
Note below from motherboard manual:
(Note: Due to chipset limitation, during the Windows® 7 installation process, USB
optical drives and USB pen drives are not supported. You can use MSI Smart Tool
to install Windows® 7.)
What is the msi smart tool? Sorry if i annoy u so much but im actually lost.
1 minute ago, Smooky97 said:
So i basically create the pendrive with the msi tool instead of the others programs i've been using and then i proceed like i was doing before on the new pc?
Yup, but don't expect stellar results. You've got a lot more headache in front of you, regarding drivers and updates.
Good luck though.
Good luck though.
You mean in windows or before i manage to install it? Cause once I'm in I'm a little bit more comfortable troubleshooting and fixing things.
