Hello, looking to build a new pc for running mass physics with thousands of pieces, running voxel based smoke and fire simulations, and then just general workstation stuff on the 3D and video side of things.
Looking to go amd and have the gpu supported by cinema 4d and nuke.
Any help is greatly appreciated, i built my current rig 4 years ago and its almost to the point of a stock bestbuy pc.
Sticking it inside a old rusted pacard bell case just as an fyi. Hoping to spend $3000-$4000
https://linustechtips.com/topic/904098-3d-vfx-workstation-help/
1 hour ago, Kamjam21xx said:
A 1950X + Vega FE ?
https://linustechtips.com/topic/904098-3d-vfx-workstation-help/#findComment-11122800
  • 2 weeks later...
Sorry, lost my login. I was thinking w9100 or wx 9100 route but im confused about pricing on them. As if there is some unforeseen advantage to the w9100 over the wx9100 im not aware of
https://www.google.com/url?sa=t&source=web&rct=j&url=https://technical.city/en/video/Radeon-PRO-WX-9100-vs-FirePro-W9100&ved=2ahUKEwjL9ZGvn4PaAhWB64MKHeVaDKUQFjAAegQICBAB&usg=AOvVaw0A1tfIl7rgdSll97YxH8me
https://linustechtips.com/topic/904098-3d-vfx-workstation-help/#findComment-11168630
