Heey!
As I see it there are a couple thing you could do.
 1. Locate the samples that come with FL and load them into the Logic EXS sampler or Drum Kit Designer
 2. If the first option won't work for whatever reason, make a mixdown of all the samples you like from FL, load the stereo track into Logix, make cuts after every sample and then put all the samples into the EXS sampler or Druk Kit Designer.
 3. Download a couple nice samples from https://freesound.org/ and put them into the EXS sampler or Drum Kit Designer.
Let me know if this helps you! I'll be happy to help you further if this does not work!
Good luck,
Alendos
https://linustechtips.com/topic/903935-logic-pro-x-help/#findComment-11123452
