Hi, I bought a PC online.
I customized it.
There is no OS installed and so requested license for windows 10.
PC arrived today - all components already built in.
I intended to connect my VGA connected monitor to the base unit and then connect my external CD/DVD writer  via USB and install the drivers for the windows 10 and varies other drivers.
However the PC does not recognise my monitor - comes up no signal.
I will be contacting IT support from the website I bought the PC from but am in a panic and so submitting this post for a second opinion.
https://linustechtips.com/topic/903898-customized-pc-issue/
I customized it.
Since you did not include a list of the parts, we can't determine what is, and is not, working.  With no operating system, the only thing you might get on the monitor is your BIOS.  To be honest with you, I have not encountered a VGA video connection is quite a while.  What is the mobo and what  is the monitor for starters and while you're at it, go ahead and include the rest of the system specs.  Did you order the machine with, or without, the operating system?
https://linustechtips.com/topic/903898-customized-pc-issue/#findComment-11120606
I customized it.
What are your specs? There could be a lot at play here. You plugging the VGA cable to the motherboard rear I/O when you have a video card for example could be the problem.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/903898-customized-pc-issue/#findComment-11120615
