Hi,
I'm having a graphical issue that is literally killing me. I've been trying to find a solution for a couple of months since I've built my PC. It really kills the immersion. The issue hard to describe but I've found a thread on Intel's forums that more or less describes it. This is the Intel thread: https://communities.intel.com/thread/115750
They said that it could be a compatibility issue and asked the guy that posted the thread to replace the board and the processor if possible. He solved the problem by switching to Ryzen.
Now, because I'm having a similar issue and don't really have the finances to replace all the parts I'm looking for some help from you guys to determine if any of my components are incompatible.
These are my components: https://pcpartpicker.com/list/2zRWZR
Any kind of a suggestion will be very much appreciated.
https://linustechtips.com/topic/903844-possible-component-compatibility-issues/
