anyone know of a tripple wall mount?
Solved by Oshino Shinobu,
For three 25" monitors? Sure. For two 25" and a 45"? Nope.
2 minutes ago, Evan beadow said:ok thanks do you have any good suggestions for 2 separate wall mounts?
Kind of depends how much you're wanting to spend. I'd recommend Ergotron for mounts, but they can be pricey, though you do get what you pay for.
TV mounts are generally cheaper as more people use them. Just one on Amazon with good reviews will do really.
