After i upgraded my system - Cpu -Ryzen 7 1800x , Gpu - gtx970 sli , mb- 370x msi xpower gaming titanium, ram 2x 8 gb Flare x 3200mhz , psu 750w 80+ bronze windows 10 pro 64bits. While game or just browsing the internet watching streams listening to music / general things doesnt over load my gpu/cpu nor the temperatures go high gpu under load (streaming and playing ) 58-63c max and cpu 55c max but even without stressing anything my pc stutters for a sec and then its fine, it makes the sound of when you are overclocking the cpu and it crashes that rombotic trrrrr sound for a second and then its fine. ( i have everything on basic nothing overclocked so i dont know whats the issue ) i use an ssd 250gb for the windows and the basic drivers for everything, the rest such as games e.t.c are on different drives.
https://linustechtips.com/topic/903557-pc-stuttering-and-fps-drops/
When you say "basic drivers", does that mean you didn't install Nvidia Display Drivers and all the various motherboard drivers?
As far as temperatures go, I would suggest double checking your cooling, maybe replace the thermal compound on your GPUs.
-Moved to Troubleshooting-
i installed all the latest drivers for  everything mb bios, and the gpu drivers e.t.c. i just dont have anything overclocked . why would i change the gpu compoud? that would void my warranty. the gpu and cpu temps when its not under load gpu- 36c max and cpu 39c max so i dont think thats the issue cause it stutters randomly
There's a good chance that your GPUs don't have a warranty anymore by now anyway. Also, I might have misread your post.
What's your internet speed like?
dont know exactly because it was in my house contract but its around 55mb download and 20mb upload , i dont think the internet has something to do with the stutter though its like my pc crashes for a second and then its okay ( it stutters and makes the sound of crashing like when its overclocked and it fails ) i dont have anything overclocked though
@Crunchy Dragon so i changed the thermal compound of my gpus (it was dry on both ) i have like 3-4 less temps tried ow underload e.t.c havent tried streaming though i ll do that tomorrow and see how it works out i ll let you know if that solved the issue ^^
@Crunchy Dragon hello again, so i did everything you reccomended but the problem is still happening , could it be my ssd? cause thats the only thing i can think off i checked everything else, cleaned everything from psu to fans , also the cpu . Im thinking maybe i need to install the windows on another ssd or nvme i have .
It's worth a try, honestly.
Reinstalling windows is a good idea. Do it up.
@Crunchy Dragon So i reinstalled windows on a different ssd  but the stutter keeps happening, for example i was watching a youtube video and it sounded a bit robotic for a few seconds and the video was stuttering. It seems like a processing issue either cpu or ram not sure
Double check your internet and RAM usage, your hardware shouldn't be stuttering like that...
@Crunchy Dragon so my ram usage when it shuttered was around 40% and the internet was normal 5mbs while watching something and differ depending of what i was watching (quality e.t.c.)
Is it possible to know the model of your 750W powersupply?
Command Centre
CPU - Intel® Core™ i7-6950X Extreme Edition | CPU Cooler - EVGA CLC 280MM | Motherboard -  ASUS X99-E WS/USB 3.1  | RAM -  Corsair Dominator® Platinum Series 64GB (8 x 8GB) 3200Mhz | Graphics Card (CrossFire) - XFX Radeon RX Vega 64 8GB HBM2 - XFX Radeon RX Vega 64 8GB HBM2  | Power Supply - Corsair AX1200i | Storage - WD Caviar Black 4TB (WD4003FZEX) | Sammsung 960 Pro M.2 SSD 512GB  | Case - In Win 909 (Silver)
Battlestation
CPU - Intel® Core™ i7-8086K Limited Edition | CPU Cooler - EVGA CLC 280MM | Motherboard -  EVGA Z370 Classfied K  | RAM -    | Graphics Card - [No GPU] AMD Navi? | Power Supply - EVGA SuperNova 1000 T2 | Storage -  | Case - In Win 303 (Black)
Operating System - Microsoft Windows 10 Pro | Peripherals - Filco Majestouch-2 NKR 104 ASCII with Cherry MX Red Switch | Logitech G Pro Tenkeyless Mechanical Gaming Keyboard | Logitech G903 Wireless Gaming Mouse | Microsoft Xbox One Elite Controller | Audio - Røde NT-USB | Sennheiser GSX 1000 | Sennheiser HD 599
