1 minute ago, GAMINGGUY said:
GUYS, I need some DOPE FIRE WOKE led strips. THEY cannot be average strips. PLEASE, relatively cheap. I WANT THEM TO HAVE DOPE STUFF AND CRAZY CRUD. no idk i just want some crazy led strips
You can get premade solutions like ones from Cable Mod or large rolls of LED's from Amazon or Ebay and wire them up as you desire.
-Moved to Modding Section-
https://linustechtips.com/topic/903513-any-cool-led-strips/#findComment-11116121
Are we talking case LED's or just a regular LED strip? If we're talking regular USB LED strips, just get a cheap one off of Amazon. I got one for £10 about 2 years ago and it's been on almost 24/7 and is still perfect. For case lighting, if you have a Phanteks case, get their LED strips. I have one myself and can't fault it. Only issue is that you'd have to buy an adapter to use it with a regular RGB header on a motherboard as it's designed to be used with their cases in built RGB controllers. If not a Phanteks case, Cable Mod do some nice LED strips. I believe DeepCool and NZXT also have LED strips designed to be used in a PC case.
Gaming PC: i5 8600k @ 4.8GHz | 16GB T-Force Delta RGB @ 3200Mhz | Asus Prime Z370-A | Sapphire Radeon VII (Dead :( ), RX480 8GB | EVGA SuperNova 750 G2 | 120GB Sandisk SSD Plus, 120GB Kingston A400 | 4TB Seagate 7200RPM , 1TB WD Blue 7200RPM | Phanteks P400 Windows 10, MacOS Catalina
Second PC: i5 3340s @ 2.8GHz | 8GB Corsair Vengeance @ 1333MHz | EVGA 750Ti SC | Cheap £7 250GB WD HDD Windows 7
LaptopLate 2009 MacBook (Core 2 Duo, 4GB Ram, 120GB SSD, 9400m, running Mojave) , Late 2013 MacBook Pro Retina (i5, 4GB Ram, 128GB SSD)
Consoles: Xbox One, PS4 Slim, PS3 slim, Xbox 360 fat still going strong after almost 10 years, Original Xbox, PS2, PS1
Phone: Realme 6, Xiaomi Mi A2, Xiaomi Redmi Note 4x, iPhone 6s (jailbroken)
Tablet: iPad Mini 2nd Gen Retina (Jailbroken)
Headphones:  Hifiman HE4xx, Phillips Fidelio X2, Status Audio CB-1,  Fiio E10k DAC, Schiit Magni 3+, Tin T2 IEM's, Astrotec S80
Keyboards:  2x Custom 60% - 1x Gateron Yellow, 1x Box Reds
https://linustechtips.com/topic/903513-any-cool-led-strips/#findComment-11116134
Just now, GAMINGGUY said:
Not pc lights, some that I could stick around my desk
What you would need are kits online then. You can cut and wire up the LED strip to the length you require.
https://www.amazon.com/SUPERNIGHT-Changing-Flexible-Remote-Control/dp/B00BP4GNRY/ref=sr_1_3?ie=UTF8&qid=1520458881&sr=8-3
https://linustechtips.com/topic/903513-any-cool-led-strips/#findComment-11116142
ok thanks.
https://linustechtips.com/topic/903513-any-cool-led-strips/#findComment-11116155
