My logitech g402 has a problem. It has a problem, where if i plug it in USB, computer shut downs and says tho following message "USB device Over Current Status Detected" and i can't fix it. I want to know if there is an option to fix it somehow so i don't have to buy a new mouse.
https://linustechtips.com/topic/903015-problem-with-my-mouse/
Well it's a safety shutdown as your mouse is drawing to much current. This usually only happens when the mouse is broken and for most people it's un-repairable. I'd suggest you try any other usb device on that same USB port just to make sure that it's really the mouse and then go and buy a new one
https://linustechtips.com/topic/903015-problem-with-my-mouse/#findComment-11111189
thanks, i've tried it and it works so it must be the mouse.
https://linustechtips.com/topic/903015-problem-with-my-mouse/#findComment-11111197
