So I finally got done building my gaming pc but I’m now having a problem installing windows 10 from the drive. It gives me this message “no drivers were found” I made sure all my booting settings were in the correct order. I have an msi b350m gaming pro. If anyone can help me solve this issue so I can finally finish up my pc I will greatly appreciate it!
https://linustechtips.com/topic/902917-need-help-with-my-pc/
1 minute ago, captain_101 said:
If you have another computer you can try making a fresh install on that and try to boot your system of it. that is what I did on my system.
I use a flash drive for installation. Can you tell me step by step on everything I need to do.
https://linustechtips.com/topic/902917-need-help-with-my-pc/#findComment-11110091
well what did was i put my SSD in a different computer (an old laptop that will run windows 10) and installed it normally, and then just reconnected it to the pc. I then went into the bios and force booted onto the drive. Windows should reconfigure the drivers, and then once you are in to the desktop, just install all of the drivers normally.
https://linustechtips.com/topic/902917-need-help-with-my-pc/#findComment-11110100
