Hey there community I thought it would be a smart idea to ask for help/opinions here before I go on a shopping spree.
Following the pinned Thread in this Forum I am just going to work down the five questions
1. Budget & Location:
I am trying to not spend more than 2000€ and all parts are going to be purchased in germany
2. Aim:
The aim of this build is mainly gaming & rendering @ 1080p. I play a wide variety of games including Overwatch / PUBG / League / Destiny and lot of new Steam games which should all run smoothly on higher+ settings preferably even new games for some time
3. I plan on running 2 Monitors at first both 1080p @ 144Hz but I will be getting a 3rd one sometime arround
I allready know which Monitor I am going to get so that one is probably not going to change for now ( https://de.pcpartpicker.com/product/rkphP6/asus-monitor-vg248qe )
4. Peripherals
As allready mentioned I am allready set on which Monitor I want, I also decided that the Keyboard should be one of the Corsair K series, probably a K70 or K95 havent found out yet what exactly the differences between them are. I recently bought a new mice so I wont need that aswell. I do need Windows but I heard I can use my old Win8 product key to activate a new Win10 copy, not sure if this is legitimate but I'll just try first I guess.
5. Why are you upgrading
I am upgrading because I just finished my Bachelor degree and previously played on an old laptop which should now get an upgrade due to the free time I have now!
So far I have decided on these components, nothing major yet:
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case
Monitor x2: Asus - VG248QE 24.0" 1920x1080 144Hz Monitor
SSD: Crucial - MX300 525GB 2.5" Solid State Drive
I hope someone of you guys can help a newcomer in the building scene out :)
~ much love Dinh
https://linustechtips.com/topic/902653-first-build-help/
https://geizhals.de/?cat=WL-918394
Thats my rig. Put the watercooling stuff away and switch the case to your belongings and ur fine :)
|| CPU: I7 6950X @4.6 (1.35V) || Cooler: CUSTOM EK LOOP || Motherboard: ASUS RAMPAGE V EDITION 10
|| GPU: 2x Vega 64 Strix OC @1762 / 1100 MHz || Memory: 16GB G.Skill Royal RGB 3200 Mhz ||
HDD: Segate Barracuda 3TB || SSD: Samsung 970 Evo 512 GB || PSU: Corsair HX 1200 W || Case: Fractal Design Define R6 Gunmetal || Fans: Corsair HD120 (x4) / BeQuiet Silent Wings 3 (x4) || Monitor: ACER XF27HU ||
Second Monitor: BENQ RL2455HM || Mouse: Logitech G502 Pretus Core || Keyboard: Logitech G810 Orion Spectrum || Headphones: Sennheiser IE80 ||
        Buildlog expirience swapping to x99:
https://linustechtips.com/topic/902653-first-build-help/#findComment-11107245
oh im sorry should be fixed now ;)
https://linustechtips.com/topic/902653-first-build-help/#findComment-11107259
