Question about headset/headphone cables
Just wondering, whats the difference in having a headset/headphone that has the cable going out from only one part of it(either only left or right side) and having a headset/headphones that has the cable coming out of both sides?
Is it only something for the looks? Is it annoying having a headset/headphones that have the cable coming out of both sides? Like dont the cables get in your way?
Specs of my PC:
CPU: AMD FX 8350  Motherboard: Gigabyte 990XA UD3  GPU: Gigabyte GTX 770 Windforce 2GB  HDD: WD Green 2TB SSD:  Corsair Force GT 120GB SSD RAM: Corsair 8GB(2X4) PSU: CoolerMaster G650M
https://linustechtips.com/topic/90262-question-about-headsetheadphone-cables/
It's mainly just how they are designed, the only real difference is that the other cable goes up and through the headband to the other driver.
There is less to break when the cable splits and goes to each driver directly, but the one cable and over the headband style is less cluttered and easier to manage.   I guess like the coiled versus straight debate, pick your poison.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
It doesn't change anything the human ear can perceive, but I'm sure you could measure some minimal difference with sensitive enough equipment.
